Audi a4 klimata kodu nozīme eng
35 atbildes uz šo tēmu
#1 pawels
pawels
  • Dzīvesvieta:RAUNA
  • Intereses:sports
Pievienots 19 February 2011 - 18:53
1 system error # system error
2 actual value feeler virtually # actual VALUE sensor virtual
3 actual value of interior feelers console # actual VALUE internal sensor CONSOLE
4 actual value outside temperature feeler wasserkasten # actual VALUE outside temp sensor water reservoir
5 actual value outside temperature feeler bumper # actual VALUE outside temp sensor more bumper
6 actual value blowing out feeler floor space # actual VALUE bloweroutlet sensor footspace
7 actual value blowing out feeler Mannanstroemer # actual VALUE bloweroutlet sensor dashboard
8 display CHECKS #
9 actual digital value answering potentiometer temperature flap # actual digitally VALUE feedback potentiometer temp valve
10 debit digital value temperature flap # set digitally VALUE temp valve
11 actual digital value answering potentiometer A/C flap
12 debit digital value A/C flap
13 actual digital value answering potentiometer Fuss/Def. Flap
14 debit digital value Fuss/Def. Flap
15 actual digital value answering potentiometer ram air flap
16 debit digital value ram air flap
17 driving speed (km/h) 16
18 actual value of the blower voltage (volt) 19 desired value of the blower voltage (volt)
20 actual value of the compressor/on-board voltage (volt)
21 amount of of low-voltage events (not volatile)
22 switching status of the high pressure feeler
23 number of high pressure events (volatile)
24 number of high pressure events (not volatile)
25 A/D value kickdown switch
26 A/D value hot light
27 engine speed
28 compressor number of revolutions
29 coding
30 software-Version
31 software index of
32 potentiometer error counters temperature flap of
33 potentiometer error counters A/C flap of
34 potentiometer error counters Fuss/def. Flap of
35 potentiometer error counters ram air flap
36 temperature flap impact coldly
37 temperature flap impact warmly
38 A/C flap impact closed
39 A/C flap impact openly
40 Fuss/Def. Impact Def folds.
41 Fuss/Def. Impact foot
42 ram air flap impact on
43 ram air flap impact folds to
44 operating cycle counters
45 interior temperature counted (Nine) dig
46 outside temperature filtered °C
47 outside temperature not filtered °C
48 ECOR of
49 error counters Tachosignal
50 service life in min
51 engine temperature °C
52 compressor power-off conditions (appendix)
53 display more actively el. Outputs x x compressor circulating air valve x water valve
54 rule code digit
55 outside temperature °C of
56 interior feelers virtually °C of
57 interior feelers console °C
58 temperature wasserkasten °C
59 temperature bumper °C of
60 blowing out feelers floor space °C of
61 blowing out feelers Mannanstroemer °C
62 sun intensity W/m² 3
63 sun intensity filtered W/m²
64 delta exhaust rise
65 delta A/C flap shift
66 time constant 1.8 seconds of
67 cold weather starting correction
68 max. correcting variable for i or sectionsection section of
69 actual value blowing out feeler foot (cnts)
70 desired value blowing out feeler foot (cnts)
71 deviation (Epsilon)
72 proportion (+heizen - cool)
#2 zuks
zuks
  • 2346 raksti
Pievienots 19 February 2011 - 20:59
http://quattro.lv/old/climate.html
5 sec :P
S4 B6 :greyrs4:A4 B5 1.8TQ(pwd by INC) :blackrs4:
#3 rucha
rucha
  • 37 raksti
  • Intereses:....euro,dolāri..
Pievienots 23 January 2012 - 15:05
Ko nozīmē šis kļudas uz klimatkontroles:
08.6 Temperature Regulator Flap Motor Potentiometer, malfunction
11.6 Central Flap Motor Potentiometer, malfunction
Varbūt kādam ir latviskā vai krievu versijas tulkojums visiem 74 kodiem?
Jau iepriekš paldies! Un kurš visuvarenais visu laiku dzēš manus postus,vismaz tad paskaidro kādēl,jo ne tēma nerakstu!!:happy:
#4 Bāka
Bāka
  • 17 raksti
  • Intereses:Kā efektīvāk pielikt seju!
Pievienots 24 October 2012 - 00:49
Rītu palūrēšu ko rādīs pirmā funkcija. :D
Biju jau aizmirsis par šiem kodiem. (izņemot 17. funkciju)
AUDI URS4
#5 IvarsV
  • 4307 raksti
Pievienots 24 October 2012 - 17:33
17. kanāls nafig nav vajadzīgs... Bet 52 tiek izmantots ikdienā :)
#6 lmp
  • 4338 raksti
Pievienots 27 October 2012 - 19:55
? wtf
#7 sweetais
sweetais
  • 10 raksti
Pievienots 24 January 2013 - 19:16
tas peec 2000 gada ... gan A4, gan A6
0 Systemerror, see separate table
1 set point of the blower voltage (volt)
2 actual value of the blower voltage (volt)
3 Setpoint Defklappe
4 Scaled setpoint Defklappe
5 Scaled Actual Defklappe
6 Setpoint feet / Mannaströmer flap
7 Scaled setpoint feet / Mannaströmer flap
8 Scaled Actual feet / Mannaströmer flap
9 Setpoint ram air / recirculated air flap
10 Scaled setpoint ram air / recirculated air flap
11 Scaled Actual ram air / recirculated air flap
12 Set value temperature flap left
13 Scaled setpoint temperature flap left
14 Scaled value temperature flap left
15 Set value temperature flap right
16 Scaled setpoint temperature flap right
17 Scaled value temperature flap right
18 driving speed (km / h)
19 Motor speed (10 rev / min)
20 software version
21 Audi indexing software
22 Hella indexing software
23 coding
24 digital value outside temperature feeler bumper in cnts
25 Outside temperature sensor in the bumper ° C
26 Digital value of Outside temperature sensor in water tank cnts
27 outdoor temperature sensor in ° C water tank
28 External temperature display in ° C
29 Outside temperature in ° C for compressor
30 External temperature control in ° C
31 Relationship sun left / right or right / left
32 solar sensor on the left filtered 10 W / m
33 Filtered sun sensor 33 right 10 W / m
34 Solar sensor left unfiltered 10 W / m
35 Solar sensor right unfiltered 10 W / m
36 Digital value of nominal value reduction as f (solar intensity, ambient temperature)
37 Ausblastemperaturabsenkung left f (sun intensity left / right) at 0.5 K
38 Ausblastemperaturabsenkung right f (sun intensity left / right) at 0.5 K
39 digital value blow-man left in cnts
40 Outlet temperature ° C in man on the left
41 digital value blow-man right in cnts
42 Outlet temperature ° C in the right man
43 Digital value blow-foot left in cnts
44 Outlet temperature ° C in the left foot
45 digital value blow-foot right in cnts
46 Outlet temperature ° C in the right foot
47 on-board voltage (pin 15) in volts
48 counters for shutdown terminal 87a
49 compressor switch-off - LOOK BELOW
50 RCN left delayed
51 RCN right delayed
52 RCN left undelayed
53 RCN right undelayed
54 discharge temperature setpoint left
55 discharge temperature set right
56 Stand-time
57 Calculated coolant temperature in ° C
58 coolant temperature from the instrument cluster in ° C
59 pull-down bit
60 Cold start bit
61 Intermittent cold start (bit)
62 heater switch-off - LOOK BELOW
63 Digital value of sun sensor left unfiltered in cnts
64 digital sun sensor value rather unfiltered cnts
65 epsilon inside
66 innentemp_filt
67 rolling Kompressorabschaltbedingungen (1xx current)
68 cycle counter
69 epsilon_ausblas_li
70 epsilon_ausblas_re
71 rcn_filterzeit
72 initial value coolant temperature from the instrument cluster +40 ° C
73 non-volatile high pressure events
74 I_anteil_li_xuc 128
75 I_anteil_lre_xuc 128
76 High-pressure transient events
77 Idle-active filtering
78 Idle timer for filtering value * 50 (Motor Temp 1)
79 Filter time for internal filter value * 12sec (Motor Temp 2)
80 key number used for operating temperature and setpoint
81 key number after 1.3 seconds after power-on
82 Corrected key number (10 times received correctly)
49. Compressor switch-off
0 Compressor runs
1 non-volatile high pressure events> 120
2 high-pressure event
3 High-pressure transient events> 30
4
5 Freon loss
6
7 Power of the magnetic coupling <9.5 V
8 118 ° C.
9 Bi-Directional Motor interface
10 Power of the magnetic coupling <10.8 V
11 Engine speed> 6000 rpm /
12
13 ECON
14 OFF
15 Outside temperature <-2 ° C
16 engine is available - RPM <200 U
17 both external sensor defective
18 actuator diagnosis
19
20 High-Speed ​​Low-Load
62. Heater switch-off
0 runs heater
1 outdoor temperature> 5 ° C
2 Sollausblastemperatur left and right <50 ° C
3 setpoint temperature flap left and right> 20 cnts
4 Sollausblastemperatur left and right <42 ° C
5 Econ or off active
6 Set value temperature flap left and right> 60 cnts
Errorcodes:
Name of fault location signal
1 Inside Probe 1,2,3,4,7,8,9,10
2 sun sensor on the left
3 sun sensor on the right
4 outdoor water tank sensor 1,2,3,4,5,6
5 external probe bumper
6 blowing out man on the left
7 Blowing out the right man
8 engine temperature flap left
9 Motor Def flap
10 engine temp right flap
11 foot motor / man-flap
12 engine air / recirculated air flap
13 potentiometer temp valve left 1,2,3,4,12
14 Def flap potentiometer
15 Potentiometer temp valve to the right
16 feet / man-flap
17 Pot Jam / recirculated air flap
18 air motor
19 Switch 2/30 bar 13,14,15,16
20 Blowing out foot room 1,2,3,4
21 compressor voltage 17.18
22 Blower 19.20
23 tachometer signal 11
24 Coolant temperature 1,2,3,4-Telegram
Errortype:
1 short circuit to ground
2 Short circuit to ground sporadic
3 Interruption / circuit to positive
4 Interruption / circuit to positive sporadic
5 engine blocks or spannunslos
6 engine blocks or sporadic spannunslos
7 Interruption / circuit to ground
8 Interruption / circuit to ground sporadic
9 Short circuit to positive
10 Short circuit to positive sporadic
11 Signal sporadically implausible
12 Adapts limits exceeded
13 Freonverlust
14 Freonverlust sporadically
15 high-pressure
16 high pressure sporadically
17 voltage <9.5 volts
18 Voltage <9.5 volts sporadically
19 Rule static deviation difference
20 rule sporadic deviation difference
p.s vai ari vaacu meelee..
http://www.tdi-umbau...imacodes_VW.htm
Šo rakstu rediģēja sweetais: 25 January 2013 - 10:12
#8 Giekalitis
Giekalitis
  • 195 raksti
  • Dzīvesvieta:Rīga, Aloja
Pievienots 24 January 2013 - 19:20
sorry varbut jau kur bijis bet varbut kāds varetu pateikt kā tikt pie  kļūdām A6 C5 ar divpusējo klimu? ja vispār tas ir iespējams
Ka tik motors rūc un rati griežas.
#9 rubb
rubb
  • 977 raksti
Pievienots 24 January 2013 - 20:01
Recirkulācija + poga ar bultiņu uz augšu. Ar kresās puses +- izvēlas kanālu, nozpiežot recirkulācijas pogu parādīsies attiecīgā infa labajā pousē. Piemēram kanālā nr 51 var redzēt dzinēja dzesēšanas škidruma temperatūru.
http://www.audiworld...tech/int6.shtml - te vairāk infas. Manam 2002 gada C5 kanāli gluži neatbilst tam, kas šajā linkā aprakstīti, bet nu kaut ko var izrakt.
Šo rakstu rediģēja rubb: 24 January 2013 - 20:05
..|R|ubb..
#10 wrc
wrc
  • 278 raksti
  • Dzīvesvieta:Valka
  • Intereses:Audi. Audi quattro. WRC. autorallijs
Pievienots 19 April 2014 - 11:15
Manam B5 pirmajā kanālā rāda 22.1
Muftu neslēdz iekšā. Skaidrojums un tulkojums:  A/C Refrigerant High Pressure Switch, static open -   Compressor remains off until switch closes  -   Kompresors paliek izslēgts līdz brīdim, kad slēdzis aizveras
Kas tas par slēdzi domāts?
Atradu un sapratu, sistēma tukša, tik nezinu kapēc.
Šo rakstu rediģēja wrc: 25 April 2014 - 05:49
#11 JoNYBoY
JoNYBoY
  • 77 raksti
Pievienots 28 April 2014 - 19:31
kāds var pieslēgt pie vag-com par saprātīgu naudu.?
un ko nozīmē klimas kļūdas 060, 056, 057, 078
Šo rakstu rediģēja JoNYBoY: 28 April 2014 - 20:05
Audi A6 3.0 tdi quattro 171kw
Audi A6 2.5 tdi quattro 132kW
#12 lmp
  • 4338 raksti
Pievienots 28 April 2014 - 22:38
21 eur ir saprātīga nauda vairāk, kā 10 reizēm? (21eur maksā kabelis. Aptuveni.)
#13 JoNYBoY
JoNYBoY
  • 77 raksti
Pievienots 29 April 2014 - 11:53
Tu tirgo kabeli?
Tev viņš ir ar CAN atbalstu vai bez?
#14 Raikins333
Raikins333
  • Dzīvesvieta:Jaunjelgavas novads
Pievienots 20 August 2015 - 12:53
Sveiki visiem!Kāds varētu pateikt kas par vainu kad a4 b6 neieslēdzas lai var redzēt kļudas?Vispār 0 emociju. ;)
#15 Val
  • 11668 raksti
Pievienots 20 August 2015 - 13:48
Drošinātāji veseli?
Atbilde uz nākamo jautājumu - visus pārbaudi. Profilaksei.
#16 shhd
shhd
  • Dzīvesvieta:Citur
  • Intereses:Audi A4 B5
Pievienots 19 February 2016 - 17:20
Manam a4 b5 97. gada sāka degt ((!)) šāda lampiņa, cik saprotu kļūda bremžu sistēmā, jautājums kur skatās to brežu šķidrumu? Jo cik esmu painteresējies varētu but par maz līmenis un ja ir par maz vai var pieliet klāt? Un kā zināt kadu liet? Problēma man pirmoreiz ..
#17 iDmore
iDmore
  • 574 raksti
Pievienots 19 February 2016 - 21:38
Ja nekļūdos, tad blakus akumulatoram..
:greyrs4: :redrs4:
( GB XXXX ) Audi A4 B5 Avant 1997 1.9TDi 66kw ..
( GT XXXX ) Audi A4 B5 1994 2.8Q 128kw LPG ..
( HS XXXX ) Audi A4 B5 1996 2.8 128kw LPG ..  [ Naglās ]
Mazda 323 BG 1990 1.8i 74kw  .. [ Naglās ]
Nissan Almera 1996 1.6 [ Pārdots ] ..
#18 DK5000
Pievienots 20 February 2016 - 12:45
:good:
#19 Dīzelists
  • 1655 raksti
Pievienots 20 February 2016 - 13:41
Varbūt antifrīzs traukā par maz, varbūt bremžu eļļa. Bremžu eļļu vari liet Dot4.
#20 Maarciss
Maarciss
  • 16 raksti
Pievienots 11 May 2016 - 10:20
Sveiki! Kāds nav saskāries ar problēmu, ka A4 B5 97.g nesaglabā klimata uzstādījumus?
- visu laiku temperatūra 22 grādi, ja saregulē kā gribās un ar citiem grādiem tad izslēdzot aizdedzi ilgāk nekā uz 30sek, uzstādījumi pazūd un atkal pūš 22 grādus.
#21 km_
  • 570 raksti
Pievienots 11 May 2016 - 11:45
+12V vienkārši varbūt nepienāk, pie aizdedzes izslēgtas. gan jau ka var būt arī dēļ beigta drošinātāja mož?
#22 Maarciss
Maarciss
  • 16 raksti
Pievienots 12 May 2016 - 08:26
Drošinātājs vesels.
#23 Val
  • 11668 raksti
Pievienots 12 May 2016 - 08:35
Jāpiesprauž cita vadības kaste ar tādu kodu, kā tavam. Vismaz pārbaudīsi, ka tas ir/nav pie vainas.
#24 km_
  • 570 raksti
Pievienots 12 May 2016 - 09:16
Ja pazūd tikai saglabātie uzstādījumi, tad var jau pielikt līdzīgu bloku, kas pa pusei iet. Tāpat redzēsi - saglabājās vai nē temperatūra.
Piemēram,
8D0 820 043 H bloks un 8D0 820 043 F šķiet saderīgi, arī kompresoru slēdz iekšā. Nezinu gan cik precīzi rēķina temp.
Mož blokam atmiņa nodegusi? Kļūdas ir kādas?
#25 Maarciss
Maarciss
  • 16 raksti
Pievienots 25 May 2016 - 09:50
Piemēram,
Kļūdas - 22.1 , 6.1 , 8.7 , 15.7 , 18.3 ,
#26 marchello4035
marchello4035
Pievienots 29 August 2016 - 07:30
kāds gan bremžu šķidruma bačokam sakars ar Klimu. dažs labs vēl to ne tā sapratīs
#27 kotletO
kotletO
  • 77 raksti
  • Dzīvesvieta:Bebrene
Pievienots 29 December 2016 - 17:32
Sveiki. Jau savlaicīgi atvainojos par kārtējo šāda veida jautājumu. Tātad kļūdas:
08.7 Temperature Regulator Flap, sporadic block
11.7 Central Flap, sporadic block
Cik noprotu 8 ir G92 jeb temperatūras regulācijas motoriņš
un 11 ir G112 jeb centrālais regulācijas motoriņš.
Bet problēma tāda, ka visos topikos šeit atradu tikai vienu - "tak izmanto meklētāju, jau 100x viss izrunāts", un tā visos, tā arī nespēju atrast kur šīs kļūdas izskaidrotas saprotamā latviešu valodā, lai zinātu vai tur viss ir slikti un jāmeklē jauni motoriņi vai arī iespējams sataisīt. Kļūdas met 94 gada a6, kurš galīgi nevēlas pūst siltu gaisu. Paldies.
#28 Fridrihs
Fridrihs
  • 982 raksti
Pievienots 29 December 2016 - 21:06
Ar ko lasīji kļūdas?
Temperatūras kļūdas (08.7) gadījumā vairāk izskatās, ka radiators aizkakājies, tāpēc nav siltuma. Tā kļūda nav 'permanenta'.
Centrālās klapes kļūdas gadījumā jauc laukā viduskonsoli un meklē motoriņus. Iet kopā ar footwell/defroster. Pie reizes pārbaudīsi arī to. Potenciometra gadījumā parasti tīrīšana nepalīdz. Vajag citu. Izdilst sliede un sāk rādīt mistiskas vērtības.
A6 C4 AAH
#29 kotletO
kotletO
  • 77 raksti
Pievienots 29 December 2016 - 21:35
Vienkārši nospiedu divu pogu kombināciju klimai un pirmais kanāls parādija šos 3 kodus. Īsti nesapratu Tavus- " Iet kopā ar footwell/defroster. Pie reizes pārbaudīsi arī to. "
Bet paldies par padomu.
#30 Fridrihs
Fridrihs
  • 982 raksti
Pievienots 29 December 2016 - 21:56
"Iet kopā ar footwell/defroster" - tāpēc, ka abi atrodas vienā kastē viduskonsolē. Tiksi pie viena, tiksi arī pie otra.
http://audi.cats.lv/...ctuatortray.jpg
Ja proti spaidīt klimata diagnostikas pogas, tad kādas vērtības tev rāda 8.kanāls LO un HI režīmā? Vienīgi vērtības jāskatās vismaz 30 sek. pēc režīma uzlikšanas.
Šo rakstu rediģēja Fridrihs: 29 December 2016 - 21:58
A6 C4 AAH
