Palīdzības Tēma: Contacting the moderating team & reporting posts
If you need to contact a moderator or simply wish to view the complete administration team, you can click the link 'The moderating team' found at the bottom of the main board page (the first page you see when visiting the board), or from 'My Assistant'.
This list will show you administrators (those who have administration control panel access), global moderators (those who can moderate in all forums) and the moderators of the individual forums.
If you wish to contact someone about your member account, then contact an administrator - if you wish to contact someone about a post or topic, contact either a global moderator or the forum moderator.
Reporting a post
If the administrator has enabled this function on the board, you'll see a 'Report' button in a post, next to the 'Quote' button. This function will let you report the post to the forum moderator (or the administrator(s), if there isn't a specific moderator available). You can use this function when you think the moderator(s) should be aware of the existance of that post. However, do not use this to chat with the moderator(s)!. You can use the email function or the Personal Messenger function for that.
Reporting a post
